Is there any Application that puts phone into Sleep mode?
3 replies · 2,270 views · Started 10 March 2008
Hi does anybody no if there is an Application that turns your phone of after 15/30 minutes, ie sleep mode, reason for asking is that i like listening to the radio when going to bed but obviously the phone will stay on all nite if you fall asleep !! So im wondering if there are any programmes out there to help me, thankyou and hope to hear soon from Brian...P-s Nokia n95 and n81 8gb..
off the top of my head no.
i just charge mine up at night, leave CClock in landscape mode and use it as a clock.
Take a look at Best Profiles. While it won't switch your phone off, it will run applications at specific times and then kill applications at other times. So you could run the radio for an hour and then have Best Profiles switch to your "powersave" profile, with everything turned off for you. Might help you.
Hi all, and many thanks and i will try the best profile one, i will let you no how i get on and thankyou again from brian
