Hello!
Recently switched from a classic 95 to a 8Gb version and now seem to be unable to find the program. Is it still working for you lot? Don't have a PC at hand here, so a dowload directly to my mobile would be awesome... 😊 better yet, if someone could mail it to me! [email][email protected][/email]
Thanks in advance, awesome forum by the way!
but it has a mind of its own, sometimes it will let you log in and others it wont, 9 times out of 10 you cant log in. very good when it does though with voice clips and what not.😊
I also am unable to find this on my phone, could somebody please post a d/l link that i can use?
http://www.symbianv3.com/files/WindowsLive_for_Series60_3rd.zip
Is the one im using i think, says i have a 30 day trial though
I haven't used mine in ages so I dunno if I've been affected by the 30-day trial thingie. Some peeps have reported that it's still working for free for them.
I`ve got N95 8Gb on 3 network.
And i had a link by the 3 to Live Messenger. Downloaded it and it looks like to me that using it is free. I`ve been using msn for sometime, checked my usage and there was not even a peny.
Had no problems yet. And i don`t think it is 30 day trial.
Can someone explain how to get this working on a N95-1?
Whenever I select the icon, nothing happens at all. :con?
dog-man
Wasn't there another sis file that had to be installed before Live Messenger would work? It could be you haven't installed it. Sorry, I don't know what it's called. Maybe someone else can reply and divuldge.
That rings a bell. I will investigate further.
Have now remembered that the app that had to be loaded first was called 'dep.sisx'
dog-man
It's up and running now.
Have logged on and sent some test messages. Chatted with someone, so it seems to be working fine. :icon14:
dog-man
your supposed to install with live messenger.sis is called dep.sisx😊
Renatt wrote:I`ve got N95 8Gb on 3 network.
I'm on 3 also, the live messenger that is on 3 phones (and downloadable from 3) is free to use through 3 and wont incur any data charge, but this version wont work on any other network or de-branded 3 phones unfortunately.
