Hello N95 people,
I recentley switched from a Sony Ericsson W850i and the music player is very different. So here are my questions...
1) How do i make it so the music player asks if it should do playback throught the speaker when I remove the headphones?
2) What software should I use for putting music on the phone?
3) Any way to modify the skin of the music player?
4) How do I manually refresh the music player?
Thanks:tongue:
1. It's not an option you can set - music WILL come out of the speakers as soon as you unplug headphones.
2. Doesn't really matter - you just have to get the music files onto your memory stick using any way you like. I just plug the microSD card into my computer and copy the songs I want to a folder called Music.
3. No. You can get other 3rd party music players though.
4. When you open Music Player, hit Options (left soft key) then Refresh.
Ok thanks, what 3rd party music players are there? do I need the certificate thing for it?:con?
i dont have refresh under options...........................
immortal_3k3 wrote:i dont have refresh under options...........................
You are not on the first screen in Music Player then, keep hitting Back until the right soft key becomes "Hide", at that point there should be a Refresh under Options.
thanks so much for your help 😊
hopefully nokia adds the thing to make my first question possible 😊
