Javascript
4 replies · 2,396 views · Started 07 March 2002
Hi Everyone,
is there a browser available for the 9210 that supports javascript. If there is one available then can you let me know where I can download a trial or buy a copy please.
Thanks and Regards
The standard browser does support javascript (and java if you have installed the java.sis). Check that the sites you are using may be using M$ hacked up Jscript (yet another attempt to take over the world).
hmmm, that's contrary to everything that I have read so far.
There is no M$ takeover on the particular page I am trying to get to. It's a Notes web interface.
Javascript is supported, but somethings wont work because of the nature of the device.
Bad scripting can cause problems as can pop up windows.
Rafe
