*NEW* AAS Comic proposals
6 replies · 48 views · Started 01 February 2003
Ok, Rafe don't get a say, I'm gonna do it anyway... YES! an AAS comic strip, maybe weekly or bi-weekly or monthly depending on how busy I am.
"Why does this bother me?" I hear you cry!
This is why!: I plan to use as many of the admin team as possible as members for the comics, what I need from you is a frontal shot (head to feet) and a profile shot (head to feet again) and these need to be both in the same outfit and against a background that doesn't match the clothes etc too much (so I can cut you out). Funny outfits are accepted as much as normal clothes. The pics don't need to be great quality so a snap with a P800/7650 will be fine for the job (I hope).
I'm not sure on a title yet, so suggestions for that are welcome too.
BTW Ewan and Rafe are defo people I want included in this. Oh and Dazler too, no backing out now (ok you can). It's completely optional by the way.
[quote="TheSpecialBoy"]Do you need Admin and Mods to strip on AAS?
I might be drung because of Chivas Regal Gidess.... 😃 😃 😃 😃[/quote]
I think you may be far tooooo drunk. And nope, no-one need strip.
Ok just a quick note to pop the pics in an e-mail to [email protected] being the best bet of getting it to me. Also if any of you fancy your gfx skillz and want to take the background out from behind your picture (and probably do a better job than me) feel free to but make sure you send the image as a .bmp or similar uncompressed format.
Background colour doesn't matter, I'd like them in true colour if preferable (but obviously not jpegs as the colours will bleed). Transparent backgrounds in photoshop or paint-shop-pro format files will also be fine (PSP prefered as that's what I work with. As for size, anywhere between 320x240 and 640x480 will be fine as it will give me plenty of scope for resizing and use of half-bodies etc.
