Is there a way / app that will show the name of the sender when it says on teh front screen whe nyou get a text that says "1 message recieved", so it would say "Message Recieved from [contact name]"? Kinda like SE phones do
Thanks in advance
Thanks in advance
You will most likely have to use a 3rd party program for that. I use SkyeCallerPro that shows a picture of the contact when they text me. Of course, it only works for contacts in your contact list.
-Cheers
Could that not show the name of the sender too?
Well it shows the name as well as the picture. I don't believe you can just default to the name without a picture. The only way to do that would be to take a picture of the name, then set that as the picture. As far as just showing the name with nothing else, I don't believe there is a program that does that, but I could also be wrong. Sorry
Ok thanks, i'll check out that app you mentioned, better than nothing heh
Here this app does what you want and much more its called S60Ticker v0.9.11 its for s60v3 and u get to chose what features you want to use on it
Here is some of the official info about it but not all info to find out more just use google or something
Application S60Ticker offers a typical Ticker in order to indicate current and important information. At present, all incoming SMS messages with sender phone number or contact information and message text are shown.
Because of the publicly available Developer Toolkits (S60TickerSDK), further applications and data services can be integrated:
* News feed
* Exchange ticker
* Mobile Banking information
* Weather forecasts
* Current music titles (play list)
* Etc.
Ah nice, i'll deffo check that out, cheers!
Urgh! I've tried that ticker before. It's plain horrible IMHO. I'd like an app that shows the details of a text as it comes in, similarly to how to SE phones do.
The closest option I can find besides the ticker is ShakeSMS. Your text is just a shake away.
a shake away instead of a slide...
Sounds like too much effort for me! 😉
SkyeCallerPro is pretty nifty. Hadn't seen that before.
And the full screen picture on incoming/outgoing is pretty nice...
I'll just need to find pictures of everyone I know now...
D
davecozens wrote:I'll just need to find pictures of everyone I know now...
zxon wrote:Raid your PC's photo galleries and crop them to fit your phone screen 😊
hahaha.... you make it sound so easy...
trawling through the well over 20,000 photos that i keep threatening to label in adobe lightroom..... maybe one day...
Yeah i hada look at that ticker one, didnt really like it, but thansk for the suggestion. And yeah i was after something similar to the SE phones
