True N95 8GB ebay seller?
4 replies · 2,564 views · Started 16 March 2008
I just purchased a N95 8GB off eBay and should receive it in two days. The description said it was made in Finland and I was wondering is there any information on the phone that would tell me this is true; for all I know it could say it right on the phone but I don't have it yet. The only thing that I noticed is that it says it comes with the 950 milliamp battery, doesn't the 8GB come with the 1200? Is there any other things I should look for that might reveal a fraud? Thank you.
Heres the link to the auction:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=330218987651&_trksid=p3984.cWON.m313.lVI
Call Nokia at 1-888-665-4228 and talk to customer service and tell them your IMEI number from there they can tell you if the product is a European version, Pacific Rim version, or the North American version. Remember the limited one year warranty is only exclusive to the North American version. To get your IMEI put in *#06# and it should tell you your IMEI.
chungdae wrote:Call Nokia at 1-888-665-4228 and talk to customer service and tell them your IMEI number from there they can tell you if the product is a European version, Pacific Rim version, or the North American version. Remember the limited one year warranty is only exclusive to the North American version. To get your IMEI put in *#06# and it should tell you your IMEI.
Thanks you info is much appreciated!😊
Ratkat wrote:It tells you where it is made on the label under the battery.
Yeah, I figured it would say it right there, then I thought about how easy it would be to switch stickers. Maybe I'm just paranoid, but it did cost a decent chunk of change and I want to make sure I'm getting what I paid for, you know? Well, we'll see it is due here tomorrow UPS ground.
