Avantgo on E51
1 replies · 3,366 views · Started 17 March 2008
Does anyone know whether Avantgo works on the Nokia E51. I'm currently having problems getting it working. Otherwise are there any other alternatives?
Thanks,
Rob
I have had it working fine, in the past. Then, for some reason, it just stopped. It prompts for my account password, and just exits. I've tried removing and reinstalling, but that doesn't fix it. I guess there's some value saved in a file or registry somewhere that's causing this, but I don't know what to delete to fix it. (I had similar problems on my iPaq, but removing all the files and reinstalling used to fix that.)
ETA: Ah, see here for how to get past the initial problem, if you're seeing the same problem as me.
