MAME PROBLEM HELP!!!!!
15 replies · 7,392 views · Started 01 February 2003
can someone please explain the whole procedure to installing a zip file for mame???I installed the mame zip file to the P800 external memory (roms) and i go to the mame emulator and it does not find any roms for mame ..any help will be appreciated
Not sure I understand you, but you just install emame which will make a ROM folder under documents in internal and external memory.
You then place the .zip file of the ROM in the ROM folder, no need to de compress it.
When you run Emame select Game, then Scan for installed games, and a list will come up of what you have.
You must have the only the game ROMS from the game list that work with this version of Emame, a lot still dont work.
There has been disscussion before and users have given a list of ROMS that are tried and tested.
Good luck.
Just one more tip is there are many ROMS for the same or slightly different game and this version seems quite specific, make sure your ROM matches the ROM list rather than the game list
http://www.yipton.demon.co.uk/emamep800/latest/romfiles.txt
I everything like you described it GAZCART but unfortunately when i try to run a rom EG pacman.zip but after cliking on it it goes to a white screen and says error librariy files missing click any button to continue, i can see from the mame screen all the roms install but all of them do that, any idea?
tried uninstalling mame and reinstalling it ,no luck.
thanks
A zip file for MAME contains many rom files e.g. MS Pacman (mspacman.zip) has the following files in the .zip:
5e
5f
82s123.7f
82s126.1m
82s126.3m
82s126.4a
pacman.6e
pacman.6f
pacman.6h
pacman.6j
u5
u6
u7
If one of these is missing, then you'll get an error message.
Well, here we go agian ...
I just can't get it to work either! I'm so mad!
I have the Yipton emame and I've tried games that are said to be working - but no...
I got one game only to work - Ladubug - and how fun is that;-(
Please, could someone point me to my favourite game, Galaxian, and give a place to get it! Send me a private mess. if you're shy...
[quote="Anonymous"] Please, could someone point me to my favourite game, Galaxian, and give a place to get it! Send me a private mess. if you're shy...[/quote]
Oops, I was not logged ...
same here and unless i've got the wrong roms for that version of emame, I've almost gave up even though pacman is my favorite game of all time!
:roll:
thanks for trying to help bobkid, i have all the files you show for mspacman, but yet when i run the rom from emame i get a white screen saying
boot1 not found
boot2 not found
boot3 not found
boot4 not found
boot5 not found
boot6 not found
error: required files are missing, the game can not be run.
press any key to continue.
help
i checked mspacman 's rom files to the ones you posted and they 're all there!
[quote="gazcart"]Not sure I understand you, but you just install emame which will make a ROM folder under documents in internal and external memory.
Good luck.[/quote]
ok got the game got the zip all good nowi run the game and it say insert coin !!! u got a coin ? lol thw question is how do u control the game ?
thanks :robot:
Thanx for trying steed but i got the rom folders, mame sees them and tries to open them but says files are missing! Mame itself works, but can't open any games.
