How do I get my GSP working, for my howm and for when I travel in USA, both seem hard to get sorted.
Any hints and tips for quick action.
Once the GPS works it will work anywhere in the world (The G in GPS means Global). What do you mean by difficult? Does it ever work?
It always takes about 3-5 minutes for me to get a fix using the internal GPS.
Are you using Nokia Maps or something else?
Do you have the latest firmware, the Nokia AU site says it is available in Australia?
Sorry forget the difficult bit I was thinking of a different post when I typed that.
What are you doing to test it?
