Connecting N95 to a wired PC with DSL or LAN internet through USB WiFi Adapter is becoming a nightmare for me. I have purchased a USB WiFi adapter, installed it on my PC with Windows XP. I am able to connect N95 to WiFi adapter, connection is established, but N95 is not routed to LAN/ DSL internet. I am unable to configure PC and N95. I don't know how to share internet through WiFi adapter. I have already activated internet sharing, but always get "no gateway reply". I am still in a fix whether it should be "Adhoc" or "infrastructure" connection on N95 and PC.
What I did on N95 is as follows:
Tools->Settings->Connection->Access points
Options and Select "New access point"
Connection Name enter the name you would like the WLAN connection to be known as on your phone - THIS IS NOT THE SAME AS THE SSID
For Data Bearer choose "Wireless LAN"
For "WLAN Network Name" enter the SSID (Make sure you match the case on your router)
For "Network Status" choose Public
For "WLAN Network Mode" choose Infrastructure "But it never connects to WiFi adapter in this mode and so have to change it to Adhoc on N95. But I tried both on wireless connection on PC.
For "WLAN security mode" choose WEP
Click on WLAN Security settings
WEP Key in use - choose number 1
Authentication type - choose shared
WEP Key settings
WEP encryption - choose 128 bits or
whatever it is set to on
your router
WEP key format - choose hexadecimal or
your router
WEP key - enter WEP key
Homepage - this isn't important
It did not work. Then I followed this procedure.
You need to define the "gateway" itself in the advance settings of the phone. This is in the connections -> access points -> " YOUR ACCESS POINT " -> select "options" on your network name - this will take you to advanced options and then select "IPv4 settings" this will allow you to assign your phone an IP address and to also enter the gateway IP from your router ( usually something like 192.168.1.1 for the router )
To get the details for your phone, Go to your PC / laptop, Start -> Run -> type 'CMD' -> In the DOS window type ' ipconfig /all '
You will notice that in the command prompt window, you have your router details like IP address and so on, you need to enter the details into your N95 on the IPv4 settings page.
If the CMD prompt window shows your computer IP address as something like 192.168.1.2 then enter a IP address on the N95 like 192.168.1.6 (just a few numbers higher, if you have two or three other machines on the network, this will still be high enough not to mess up their assigned IP adresses from the DHCP server, which will be in assending sequence - 1,2,3 etc.). This will give you a static IP adress for the phone, so the DHCP problem will no longer affect it.
Thats all on N95. But it did not work either. I know N95 is not routed to LAN/ DSL internet, and there is something to be done on PC.
On PC I setup a new wireless connection, tried both Adhoc and Infrastructure but of no use.
Please someone tell me where am I wrong.
