Hello Chaps,
On my E90, when I install / uninstall a Java app or game, some of my other apps and games move from the launcher folders I put them in back into the Installation folder.
Also my device shipped with "Pocket Express" installed in ROM - it's a Java app too I believe, the problem is that it multiplies - Pocket Express now appears 11 times in my installation folder, none of them can be removed.
Is there some sort of Java registry clean up tool I could use?
Also, where are the Java files actually stored? I've got X-plore installed and I still can't see anything in there.
Cheers.
Installations Folder and Java Problems
..so nobody else has this problem ?
I did have this problem with GMail and Widsets, I remember. The shortcuts were not moving about, so can't help there, but it was not possible to remove the items using the Application Manager. The 'remove' command just didn't work. I never did get to the bottom of it but it went, of course, when I updated the firmware to the latest and doesn't seem to have happened again. Have you done this?
Sorry I can't help, but just so you don't feel alone 😊
Tim
Thanks Tim, there was tumbleweed blowing across this thread..
Maybe I should try a firmware upgrade then - with any luck it may solve the incredibly annoying behaviour of the "edit" function on the # key...
