Soft Reset N95 8GB
1 replies · 8,209 views · Started 22 March 2008
I'm just about to do a soft reset on my phone. Just want to double check what I'll loose. Would I need to reinstall apps on the E: drive as well? or just the apps on the C: drive.
Also I think some apps on the E: drive add some files and folders on the c drive. Should I back these up in case those apps don't work anymore??
Please I need all the info possible about doing a soft reset.
