three applications
1 replies · 1,955 views · Started 22 March 2008
I would like to upgrade the firmeware on my three branded n95. I would first like to be certain I can get hold of all the apps that are currently on the phone inc three version of sling mobile.
Can anyone point me to a place where I can get the software that is on the phone so that I can reinstall everything as is post upgrade.
Also jsut to check should I change the code back to three version after upgrade?
As long as the phone is still Three branded, when you re-flash you'll still have the Three Launcher app. This will link to the apps you want and allow you to download them again.
