Can i do this??????
2 replies · 1,174 views · Started 23 March 2008
Is there anyway that when i recieve a bluetooth file i can select were it goes, i.e straight to Flash memory on the 8gb.
I hate the fact that it always goes into your inbox on the phone memory, as you cant send large files.
Is there a workaround on the phone with the current software, or do i need a third party app????
Please help if you can its driving me nuts.......
You can change where your inbox is stored (at least you can with the N95-1). If the 8Gb one is the same, try going to:
Messaging -> Options -> Settings -> Other -> Memory in use
It's probably set to Phone memory at the moment. Set it to your 8Gb drive instead. AFAIK it should ask if you want to copy/move your current messages to your new storage medium so you won't lose your existing messages.
