Does the E90 have a backlight keypad ?
3 replies · 3,486 views · Started 24 March 2008
Hi there, new here,
Does the e90 have a backlight on the keypad for use when traveling - so i can use it at night in the back of a taxi for example?
Any help would be grateful
Thanks Mikes1
Is the answer to activate press the bulb key top left hand corner of internal keyboard underneath the desk key.
just open your E90 so you can use the PDA screen for lighting purpose.
this is much brighter😊
If you're referring to the outside 'keypad' then it should come on automatically with ambient light levels.
The inside 'keyboard' backlight can be activated by pressing the 'bulb' key, top left, as shoppy says, but beware that the level of brightness is very low, so unless it's *really* dark you may not notice. I'm hoping that Nokia will sort this (if possible) in the forthcoming (?) firmware update.
Tim
