:con? hi all yes i am new and want to learn.
i bought a nokia n95 8gb and already i am not impressed with it .
first off cant get it to install themes downloaded of the net , yes i know this is a subject talked about in the past but i have tried solustions but none work .help please.
is there a software to make my own themes and install them into my n95 8gb?
also can you advise me as to how much it costs to use voice on gps ? tried installing garmin mobile but wont find internal gps and ideas please? i am with vodafone.
:frown:
making themes
"first off cant get it to install themes downloaded of the net"
Yes, no problem, if they are for S60v3!
Go to symbianthemes, and download thousand of themes for S50v3.
"is there a software to make my own themes"
Yes, search on Nokia Site... I don�t remember the name, but it�s easy to found.
"can you advise me as to how much it costs to use voice on gps"
It depends. If it�s a software like Ndrive, Route66 or Tomtom, after purchase of software it�s free. If it�s something like Nokia Maps, it�s a fee for use.
nj7 wrote:"is there a software to make my own themes"
I don't know if it's the definitive program to make themes but I've used Carbide.ui Theme Edition.
Yes, it�s one of then. Th others are here: http://www.forum.nokia.com/main/resources/technologies/nokia_themes.html
