Am I right in presuming there are no applications that work with GPS, and allows voice guidance that don't require subscriptions (Nokia Maps) or a constant data connection (amAze etc)?
N95 Gps
well garmin doesnt need the web, since it can store all the maps on the memory card. but its a one time fee, so i guess you're right.
Don't think so. But you can contact Nav4All and see if they can supply a full area map.
@RogerPodacter:
If Garmin comes on a memory card, how would that work with N95-2? Or would the files just be transferrable to the mass memory of it?
MontyN95:
Maybe I'm not using it right but doesn't Nav4All require GPRS?
chrisa86 wrote:@RogerPodacter:
If Garmin comes on a memory card, how would that work with N95-2? Or would the files just be transferrable to the mass memory of it?MontyN95:
well we cant really talk about that stuff here. but there are ways to get garmin on any mem card and even the n95 8GB internal memory. if you purchase garmin it might help you justify using this method since all you are doing is putting it on the device you want. but i've prob already said too much. google it!!
