Apps uninstallation problem
4 replies · 1,929 views · Started 24 March 2008
I've searched the forum for an answer but non were relevant to my problem and I applogise in advance if this already had been posted by someone else.
Problem is that when i install apps on my n95 i can't delete them because they don't appear in the apps manager. Some apps do appear but not the theme apps.
i had this problem a year or so ago on my n73
I am currently struggling to remember how to do it tho!!!!
I currently have no themes installed on 8gb, apart from the those pre-installed.
Firstly go to themes as if you where going to change them, and press the 'c' button.
Or trying download x-plore or y-browser and see if you can find them anywhere and try deleting that way.
Failing that hold on and i will try to figure out how i did it, unless someone beats me to it.
bashmkhan wrote:I've searched the forum for an answer but non were relevant to my problem and I applogise in advance if this already had been posted by someone else.
As requested, sorry the delay.
Its an extract from another forum.
'You need to hook up your N95 to your PC via the USB lead and access the data transfer mode, and you need to make sure your file explorer can view hidden folders.
You'll find the theme files in a folder named 'Private', in this folder are lots of other folders. Go to the folder named '10207114' and then enter the folder inside called 'Import'
In here are all the themes on your sd card.
You have to open every folder and then look in the skn folder to find the name of the theme as the folders are named by numbers and not the theme itself, if the PC doesn't allow you to open the file then choose to open it with Notepad, then scroll across until you see the name of the theme and usually it'll say the creators name too.
Once you know it's the theme you want to delete then you have to delete the whole folder including the mbm,mif,ini and skn folders.
Job done'
Sorry for the delay,
Marc:icon14:
