hi all
i bought a n80 that was proirly owned by somebody else.
When i tried to hard or soft reset it via the code *#7370#, it wouldn accept the default code that 123456
is there any way to erase those codes?
I have already tried upgrading it through the online service and the master code doesnt work either
thanks in advance
pin code problem
Just guesin, but shouldn't the code be just 12345?
yes the default is 123456
but somebody changed it
now there is no way to know wat the old code was..
so i need to erase or break it
any help!
uchi wrote:yes the default is 123456
any help!
I do believe baliator is correct on the code, it's only 5 digits (12345...just like in SpaceBalls 😊)
o sorry
i didnt read the rep carefully
well found a software that clams to unlock all codes
hoping that i would work
thanks for the help
the application is "Unlock ME"
for any one else having the same problem
i havnt tried it yet so do it on your own risk
