No Ringtones After Flashing to V21
7 replies · 2,394 views · Started 26 March 2008
If you can see the Z drive, you could always copy them from there into the appropriate folder.
Sorry, I'm not being clear. I'm in a bit of a tizzy trying to rebuild everything as I didn't just do a restore as I said I would.
In tools - general - personalisation - tones, if I go to change a tone, the only options it gives me are 'download sounds' and 'off'.
OK just copy them from z:\system\sounds and paste them into c:\sounds\ . You can do it by installing Y-Browser.
Thanks. (Previous posts actually crossed in the ether). What I have to do is play them from Y-browser then in the music player choose options - use as ringtone. Bloody annoying, but at least I'm not the sort of person who changes his ringtones every few days. And I won't be able to use that workaround for other alerts.
Have you got loads of songs on your memory card?
I have the same problem, I think it happens when you pass a certain number of songs.
I took my memory card out and all the ringtones I had previously put on the c drive appeared in my settings menu.
Strange, but I can live with it.
jstockda wrote:Have you got loads of songs on your memory card?
Yes. That's interesting. Maybe the routine that's supposed to list all possible tones sees how many there are and thinks, "sod that for a game of soldiers".
In my case, all the correct tones on the Z: drive suddenly mysteriously re-appeared after a few restarts.
Poor show.
