having just updated to V15 for the N95 8GB via NSU without having to debrand my phone (i'm on o2) I can see no added programmes such as Video Editor or any change whatsoever. Apart from the fact that I have now lost the activation key for Spiderman - I may as well have stayed on V11. Can anyone enlighten me as to what changes I should be seeing if any? Thanks
NB: have already checked the sticky and seen what changes there were to V15
Details of firmware updates are outlined in this thread.
zxon wrote:Details of firmware updates are outlined in this thread.
Yeah thanks, at the end of my message i said i had already seen this. My question is why am I seeing none of these changes?
Ahh I see there's nothing for v15. I don't have an 8Gb one myself so couldn't comment. However I took the liberty of fishing out the v11 -> v15 changelog for you. Hopefully it'll be of help.
Changes/improvements made from MCU SW 11.0.026 to version 15.0.015
New Features:
- Flash lite 3
- Widgets
- Video Editor
Browser:
- General stability improvements for browser
Messaging:
- Mailbox wizard correction
- Improvements to email viewer
Connectivity:
- Bluetooth remote volume control improvements
- WLAN connectivity improvements when power save enabled
- Improvements to WLAN connectivity
- WLAN stability improvements
Telephony:
Others:
- Improvements to maps startup and closing
- Music player maturity improved
- Headset stability improvements
- Correction to Chinese input in search application
- Improvements to power consumption (sleep activation)
- Improvements to memory handling in boot up
- Stability improvements to gallery
- Correction to video center thumbnail creation
- Improvements to applications installer
- Improvements to find function in music library
- Night mode improvements in Camera
- Correction to FDN (SIM initialization)
- Improvements to switch application
- Performance improvements to eMMC access
- Startup settings data updated
- Default input method changed to BPMF when using Chinese language
- Improvements to call history in call logs
- Localization corrections
If you don't notice any of these changes, maybe a reflash is in order. It could also be that maybe o2 have removed certain features, cos that's what some providers do for some reason. It could be that you may have to change your product code to a generic one and reinstall the firmware. Could someone on o2 with the 8Gb model confirm for baconroll if these apps are included in the o2 v15 firmware?
Thanks Zxon this was most helpful of you.
I think your right - certain features might have been removed because of O2, I noticed that this was the case on my N95-1 when I updated. I had to revert to the generic code then reinstall firmware before I saw the changes. I might do this - however I shall wait a bit first to see if anyone answers who also is on O2. Cheers.
There is'nt actually a video editor program what you open up with a icon.It's built into the gallery etc you get a edit option in the options when you have a video hilighted it enables you to merge video's change sound ,add text or cut the clip
None of the changes in v15 are that visible you really need to look hard to notice them.Apart from the Flashplayer and being able to play flash videos in browser
ccraig wrote:There is'nt actually a video editor program what you open up with a icon.It's built into the gallery etc you get a edit option in the options when you have a video hilighted it enables you to merge video's change sound ,add text or cut the clip
Thanks - at least you've cleared up the video editor mystery for me, just couldn't find it anywhere
