Hey all, I wanna change my N95 8gb's product code from the default one to the EURO1 code.
Are there any risks to changing the code? And how can I avoid them? I plan to follow the sticky instructions and I won't use a code from the classic N95 or anything like that...could something still happen?
Thanks.
that is the only concern I have .. check the sticky above.
Good Luck!😊
seki wrote:that is the only concern I have .. check the sticky above.Good Luck!😊
Well I have a n95 8GB with no updated firmware (just got it). Can I change it to;
0549487 - EURO1
Will it be for my model?
D3lit3 wrote:Well I have a n95 8GB with no updated firmware (just got it). Can I change it to;0549487 - EURO1
N95 8GB product codes
0550348 - FRANCE
0550352 - ALPS
0549487 - EURO1
0550359 - EURO2
so yeah .. looks good! 😊
