My N95 wont switch on properly
1 replies · 4,170 views · Started 31 March 2008
I turned my n95 off just now because i would open a messeage only for it to be closed a second later but now it doesnt turn on properly. I get the white background with nokia the nokia disappears just to leave the screen white. I dont get the screen asking for my passcode. Ive turned it off and taken battery out but that hasnt helped.
Anyone else had this happen to them?
try that and report back ..
TAKE OUT the Memory Card.
beyond that (we're looking for a screen fault first) you might try hard reset.
GREEN and * and 3 buttons while switching on.
this will dump all your settings etc.
- also try plugging into your PC to see if the Nokia PC suite or something else will recognise it.
- if none of this works you're best off taking to a nokia store for testing/repair/replacement
Good Luck!😊
