Backing up messages
11 replies · 3,466 views · Started 31 March 2008
I'm having huge trouble backing up my text messages.
When I had the original firmware, I could copy messages from my phone's memory to my flash card and viceversa. Now, with firmware 20, I don't have that option and I'm kind of puzzled about what to do.
How can I copy the messages from my phone's memory to the flash card or from my flash card to my phone's memory?
Well you were lucky ive never been able to back up messages. If you set the message memory to car it will move everything on but theres never been an option to move back.
questura wrote:just seen this...not sure if it will do what you want, but possibly
http://thinkabdul.com/2008/02/01/voice-sms-reader-for-s60-automatically-reads-aloud-incoming-sms-text-messages-as-they-arrive/
Hi, thanks for your answer.
Based on what I read, the primary function of the app is to read SMS aloud and it does allow backing up of the Inbox only.
I can't believe that a phone this advanced can't copy SMS from one place to the other in a flash.
Does anyone know where they get stored and if they can be copied manually?
open messaging / options / settings / other / Memory in use .. Change from phone memory to memory card .. at this point you're offered the chance to copy the messages to memory card .. do it 😊
of course you can also use PC Suite to back up to your PC .. you should do this too! 😊
seki wrote:open messaging / options / settings / other / Memory in use .. Change from phone memory to memory card .. at this point you're offered the chance to copy the messages to memory card .. do it 😊
I've already tried this several times to no avail.
daiver wrote:I've already tried this several times to no avail.
and upgrade to v21 ..
if your PC suite won't backup messages you need a more recent version.
You should install the latest version before upgrading to v21 anyway.
Let me know how you get on!😊
seki wrote:and upgrade to v21 ..
Oh, PCSuite works, but the first method doesn't.
Basically, what I want to do is copy all SMS to the phone's memory for faster access to them. I have over 3000 SMS stored in my flash card and access times are just too slow for my taste.
So will PCSuite copy all the messages from my phone's memory AND the ones already in ym flash memory and bundle them in one big SMS database that can later be copied into my phone's memory?
Thanks!
with folders .. but I haven't got PC suite here 😊 so I'm not sure if the two sources can be merged.
The copy option does seem to be a oncer too!
Probably a flag someplace to re-enable that.
SO here's a plan - dunno if it will work for sure.
Take any messages on the phone memory stick them in a new folder (eg backup)
backup everything using PC suite .. do a hard reset Green and * and 3 while turning on.
try the copy option now
If a hard reset doesn't help try an upgrade to v21 (or reflash v20) then
try the copy option again.
Give it a go - like I say dunno if its gonna work!😊
oh oh oh!
i just found this and it's amazing - sorry if it's old news, but i just fired it up and it backed up my phone online immediately 😊
http://www.handango.co.uk/PlatformProductDetail.jsp?productType=2&platformId=4&siteId=172&productId=215058&sectionId=6184&posit=125&catalog=20&topSectionId=5636
Bloove is web-based mobile phone management service. Edit your contacts, make calls and work with SMS using your favorite browser.
Bloove is like PC Suite for the web. It allows you to manage your phone via web browser without cables or Bluetooth. Only data connection is needed. This version has support for:
* edit contacts on the phone
* store contacts in the archive
* send SMS messages and initiate calls
* manage Speed Dials
* work with Inbox, Sent, Drafts and other folders
* archive old messages to free some space on the phone (you may restore them later)
* view message history threaded by contacts
* work with log: Answered and Missed call, Dialed numbers, Data sessions
* *NEW* edit contact thumbnail pictures
All available functions are free for now; we are planning to add premium features in forthcoming releases.
After downloading and installing agent go to www.bloove.com using your desktop browser, sign up for an account (only user name and password or OpenID is required) and connect your phone to the account by entering ID displayed by agent.
Thanks for the great link. I was actually looking for similar software, but was unable to find it.
layla17 wrote:Thanks for the great link. I was actually looking for similar software, but was unable to find it.
no worries - i literally just stumbled across it and tried it out. works so so well 😊
