W960i---Getting videos on there?
1 replies · 3,514 views · Started 01 April 2008
Hi....Im trying to get some videos off my pc onto my new W960i but they dont seem to want to go on.Is this possible or do you have to buy the GO-PRO software to do this.On my old 950i i converted the videos to mp4 then transferred them but those converted videos dont seem to want to go on the 960i?.
Any help appreciated.....Jon
I've had both the w950 & the w960. The videos you converted for your w950 should play on your w960. There's no reason why it shouldn't.
If you're lookin for a converter, I would suggest that you try M3. Just search the net. It's free & you get a high quality output.
