munkiii wrote:have you read this...
http://finestfones.blogspot.com/2008/03/symbian-92-has-been-hacked.html
and then this? (scroll down to the orange text then read from there)
http://finestfones.blogspot.com/2008/03/guidetutorial-how-to-install-unsigned.html
it's confirmed working by me at least, dunno if other people have had problems with it.
thanks munkii...
I've been trying to get this to work using the steps following the orange text in your 2nd link...
"1) copy all the .py files from the Resource folder in the zip file into C:\RESOURCE on your phone.
2) copy the unsigned sis you want to install into the root of the mass memory on your phone and if needed, rename it to something simple, for example, change "finestfonesownz123456unsigned.sis" to "finestfonesownz.sis"
3) you'll now need to edit the UnsignedInstaller python script that's in the zip file by using notepad. Once you've opened it, hit CTRL+F and search for myunsigned which should bring you to that line. Edit "myunsignedfile" to the name of your application, so in my case it would be called finestfonesownz.sisx. Once you've edited the file, save the file and copy it to the Python folder on your phone.
4)On your phone, open the UnsignedInstaller using Python and wait for it to finish and your app will now be in your applications folder!"
However when it comes to running the final step, i get this
File "E:\private\2000b1a5\default.py", line 81, in menu_action
f()
File "E:\private\2000b1a5\default.py", line 65, in query_and_exec
execfile(script_list[index][1].encode('utf-8'😉, script_namespace.namespace)
File "e:\python\UnsignedInstaller.py", line 32, in ?
import sisinfo, sisfields
File "c:\resource\site.py", line 112, in platsec_import
raise ImportError("No module named "+name)
ImportError: No module named sisinfo
So....still fail. Driving me up the wall :frown:
