n73-5 no 3g
2 replies · 3,983 views · Started 04 April 2008
my n73 dont have 3g...in tools-settings-phone dere is no network option to make it dual to gsm mode.... it is n73-5 firmware ver 4.0726.2.1.1 ...can i get it to n73-1 with a firmware upgrade? some forums saying that is possible as its only a software diff as n73-5 have two cams n stuff...or shuld i take it back to my dealer and get a n73-1 instead of n73-5..n73-5 Rm-132 dont have 3g
the only chance to get your 3g is to change the product code of Rm-133 .. you can find in this forum...
and flash to the newest firmware nokia has right now which is the 4.073xxxx
you're lucky your firmware is 4.072 .. and has another level of upgrade available...
Some of the software versions have disabled 3g net.
Talk to your dealer if it doesn't work with your current software version
