Hi, ive been trying to install a few games on my N95 lately and ive been downloading them from Mosh. Ive been saving them as .jar files.
Usually you can just double click on them and they install if everythings connected.
But they are not working. 😡
They all worked fine before updating my phone to V20.
Help please. 😊
It looks like it may still be inside an archive .. just double check you've expanded the files first prior to "installing" them.
seki wrote:It looks like it may still be inside an archive .. just double check you've expanded the files first prior to "installing" them.😊
I dont think its that. :dontknow:
if you expanded them from an archive, Vista might have screwed them up.
If you have another way to extract them from their source, try that .. even an xp machine might do to fix your problem.
don't double click on the jar file, just send it to the phone instead. then load it on the phone and it should start to install.
munkiii wrote:don't double click on the jar file, just send it to the phone instead. then load it on the phone and it should start to install.
Try installing them using PC suite,
