OK, newbie 1st post - many questions
5 replies · 2,874 views · Started 03 February 2003
Picked up my 7650 (UK, Orange), and so far so good, but some questions not answered by the manual (!)
1. Contacts - the manual shows sorted firstname, surname, but Outlook 2000 contacts are displayed last, first, and there seems no way to change this, other than editing 1100 outlook contacts.
2. As I have a 1mb wireless cable connection at home, can I bridge (XP) this to the 7650 via Bluetooth, so when at home, I use that for browsing, not Orange GPRS ? (My wife uses the PC a lot....)
3. The camera actually takes the picture about 1 second after the camera noise - is this normal, can it be improved ?
Firmware 3.16
Operator: Orange (Locked SIM card), UK
Many Thanks in advance...
En Croute
Welcome to AAS 😃
1. go here: http://www.compsoc.man.ac.uk/~ashley/
2. Yes, do a search in AAS
3. Its normal, forget the flash sound 😃 But its shorter than second in my phone (like 1/2 second or so)
I use Photographer. There seems to be no delay there. The photo takes a little while to display but it is actually the image that was there as soon as I pressed capture.
Hope it helps.
switch the profile to silent, meeting or another that turns off the shutter noise, then the pic will be taken at the right time 😊
