Ey Up, I installed a small app that repeatedly reads out the name of the caller in short pauses in the selected ring tone. My problem is that I can't remember what it was called and I can't see anything in App Mgr that looks familiar if I wanted to remove it.
Has anyone any ideas? :redface:
Peter
Are you sure this is an app? There is an option to do this built-in. Go to Settings > Personalisation > Tones > Say Callers Name
3Shirts, cheers for your reply. It may well be that what you said, I just went to settings and knocked it off. 😎
Cheers.
It's called the Stephen Hawking caller announcement, standard with S60 😉
