Product code 0558086 for N95 8GB can be upgraded to v20 now...
33 replies · 9,914 views · Started 07 April 2008
N95 8GB with this product code 0558086 (that's the code for the Norwegian market) can be upgraded to v20 through NSU now. It allows English to be set as the language also...
Ben Frain wrote:N95 8GB with this product code 0558086 (that's the code for the Norwegian market) can be upgraded to v20 through NSU now. It allows English to be set as the language also...
Hey Ben - is it safe to use? I've only had my N95 8GB 2 weeks and don't want to 'brick' it!! I'm taking it that once the UK version is out I can change the code back and reflash?
Cheers
I upgraded the NSU first and then when I tried to change product codes with NSS it won't let me. I can only assume the new USB drivers in the software updater cannot be understood by NSS.
As previous poster states, upgrade to v20 definitely not available in Euro 1 code trough NSU yet.
Ben Frain wrote:I upgraded the NSU first and then when I tried to change product codes with NSS it won't let me. I can only assume the new USB drivers in the software updater cannot be understood by NSS.
Wish I hadnt upgraded NSU now - cannot change to the Norway code through NSS and I wanted to upgrade to fw 20 tonight.. grrrrrrrr
It's true - I had to use another machine to change my product code... must be a change in the drivers that NSS doesn't like.
It's back to Euro1 now though...
As for screen rotation, it seems just as good as samir's one...
what do you mean? I just checked and it's still not available on Euro1 and cant change code now on NSS
this is wierd after I updated NSU, NSS will not read the values again..........spooooooky. Anyway for the people who updated does the new firmware allow UDP or whatever it is called that keeps your data intact ???
baconroll wrote:It's back to Euro1 now though...
I believe he means, having updated using the other code, he has set his phone back to the EURO1 code.
dorisall wrote:this is wierd after I updated NSU, NSS will not read the values again..........spooooooky. Anyway for the people who updated does the new firmware allow UDP or whatever it is called that keeps your data intact ???
As discussed above - you will need to do the NSS product code switching on a machine that hasn't got the latest NSU on.
With regards UDP - I would guess not. I read a thread on the Nokia discussions site, and I quote...
"Well... the new firmware is working fine, yes... But even though I did a backup-upgrade-restore procedure some of my programs lost their settings, and one or two programs disappeared altogether... :-/
I also have the N-Gage 'file not found' issue, mentioned in some other posts.
I'm seriously considering an install from scratch..."
Ben Frain wrote:I believe he means, having updated using the other code, he has set his phone back to the EURO1 code.
oh yes, sorry that's what i meant... i took it back to the other machine and changed the code back to EURO1.
Auto rotation is great, very impressed.
Only problem I have is that Conversation won't launch. chrisa86 - do you have this problem?
I CANT UPDATE USING NSS
eveytime i go to Phone info and press SCAN, it just says
Scan for product..............error!
whats going on?
i know that already, but my NSS wont even scan for phone info, it just says error!!!!!!!!!
this is not the problem you have mentioned!
If you have already updated your Nokia Software Updater it is. Have you? That is exactly the same problem I and others have had. You will need to run NSS on a system that you have not upgraded the Nokia Software Updater on.
Have you updated Nokia Software Updater on the same machine?
ALL SORTED NOW THANKS!
updated on my other PC and just installing new firmware to version 20
is Version 20 a lot better?
i guess i will have to change language to english as i have changed product code to 0558086 which is Norwegian
this is sound ok to you then?
this really sucks - how come the Norway code is available and not the Euro1? Also - was gonna update to Norway until someone said you need to update NSU 1st because Euro 1 was available! How long we got to wait for the Euro1 code - anyone know?
It seems you guys changed your product codes unnecessarily. My UK code handset is now updatable. Just restoring my settings as I type.
I havent changed my code I have the code of 0549487 which is Euro1 - how can you be updating yours, Euro 1 is still not available, please explain, thanks
My product code is 0558787 which is apparently a special UK code for 'N95 8GB UK CV Warm Black' - the reason for the different code for is to do with it coming with Spider-man 3 according to some forums. Anyway, I checked this morning and it still wasn't available but by 7pm tonight when I checked again it was.
I just had a look and Euro 1 still isn't though, you are right!
I guess it will appear in the next few days. They seem to be doing smaller batch codes first for some reason.
ok thanks mine came with spider man on O2 and it didnt have that code it had 0559497 so guess i will have to wait - btw, does it work and whats it like?
