N-Gage causing phone crash
10 replies · 2,932 views · Started 07 April 2008
I downloaded and istalled new n-gage software on my n95. When i open it and try to connect it to the internet via WLAN the phone basicaly crashes and restarts. Is anyone else having this problem or is it a unique one?
I've downloaded it onto my N95 and it's working fine.
I've got the latest V21 firmware. Are you on the latest?
what firmware is your phone on b/c you need atleast v20 on n95 to run it with no problems and v15 on N95 8gb.
and games what you purchased during 1st access must be redownloaded and reactivated using you activation code
No, you're not the only one. I get a crash if trying to change the network settings. For some reason it picked T-Mobile MMS as a default and whenever I try and change it the program crashes, sometimes needing a battery out to reset it properly. 😞
I am on v21 firmware. Yeah it tries to connect to the GPRS but it crashes when i select WLAN connection.
chrsfrwll wrote:No, you're not the only one. I get a crash if trying to change the network settings. For some reason it picked T-Mobile MMS as a default and whenever I try and change it the program crashes, sometimes needing a battery out to reset it properly. 😞
chrsfrwll, I have the exact same problem as you. Haven't found a solution yet.
Make sure you do not have an Apostrophe in any of your access point names. For example if you have an access point called Web'n'Walk, try renaming it to T-Mobile Internet.
Tim1980 wrote:Make sure you do not have an Apostrophe in any of your access point names. For example if you have an access point called Web'n'Walk, try renaming it to T-Mobile Internet.
Well that sorted the connection AP selection issue, thanks.
