Can anyone suggest/recommend a good pair of 2.5mm earbuds or earphones for my E51 please?
I do NOT like using 2.5mm to 3.5mm adapters :icon13:
Model numbers and supplier would be much appreciated.
Which earbuds for my E51??
Just so happens I bought some recently, I dont like adaptors either.
http://www.amazon.co.uk/exec/obidos/ASIN/B000UE28CE
Slightly pricey, but then all 2.5mm headphones are. In fact these are about �5 more than the same version in 3.5mm.
Comes with adaptors, in case you have smaller or larger ears than normal.
Have found them to be very good.
bartmanekul wrote:Just so happens I bought some recently, I dont like adaptors either.http://www.amazon.co.uk/exec/obidos/ASIN/B000UE28CE
Thanks bartmanekul - I have already seen these but was unsure whether I fancied the "asymetrical" cord - are they comfortable with this type of cord or do they want to fall to one side like many others that are "lop sided"? :con?
Really depends how you use them. But even though I use them when exercising (thus hanging in a straight line), they dont seem to pull to one side.
ziffos wrote:Thanks bartmanekul - I have already seen these but was unsure whether I fancied the "asymetrical" cord - are they comfortable with this type of cord or do they want to fall to one side like many others that are "lop sided"? :con?
Sincere apologies if this is obvious, but you do know that the longer lead is mean to go behind your head? In which case there is no issue(Or I have never noticed one) with them falling out?
Thanks Guys, CX300's now ordered from Amazon.
You can of course get a little adaptor for about £2 to use good 3.5mm headphones with... Check out amazon and ebay but watch for the ones people say are tempremental...
greenlikeapples wrote:You can of course get a little adaptor for about �2 to use good 3.5mm headphones with... Check out amazon and ebay but watch for the ones people say are tempremental...
Thanks greenlikeapples but as I said in my openning question - I do not like adaptors! :icon13:
Have you got them yet, let us know what you think of them.
I tried those amazon ones, had to send them back, always fell out my ears 😞
bartmanekul wrote:Have you got them yet, let us know what you think of them.
Arrived yesterday - put them through their "paces" last night and :-
Sound quality - excellent.
Ear fit - excellent.
Build quality - excellent.
DISLIKES:-
Do not like the asymetrical cable (I still prefer central/equal cables).
Definately do NOT like the right angle connecter (would have preferred a straight connecter).
Do not like the fact that they are about 5 GBP dearer than their 3.5mm "brothers".
Overall - I would recommend these 2.5mm CX300's to anyone providing they are willing to "put up" with the above dislikes.
Thanks bartmanekul for the original recommendation.
