How to make the bluetooth signal stronger?
1 replies · 3,059 views · Started 03 February 2003
Is there any way that you know of to make the bluetooth signal stronger? by means of some program or something to allow it to use more power?
Because it sais 10 meters range.... but that are 10 VERY small meters....
There are different classes of BT device. I think the one we uses is the low end one. There is no way to boost the signal strength unless you have the booster hardware.
