Hi all,
Im going to be ordering one of these for my 7650 this afternoon but first wanted to know which of these apps you thought was better??
Which was fastest and compressed most memory??
Which would you recommend i go for?
Thanks in advance!
Hi all,
Thanks in advance!
The Stacker looks nicer.
Both pack about the same. sDoubler is maybe a bit faster, but just a bit.
And both apps have really good support.
I myself use sDoubler.
I would go for Stacker too
HI!
I think that "The First Rule" for every 7650 zip software is ... BE SMALL 😃
So.. SDoubler use less mem installed than Stacker...
I don't care about the look in this kind of apps because you actually
don't see it too much 😉
average compression time and amount is almost the same..
so.. i use SDoubler 8)
cya!
Alejandro
I use sDoubler too!
Ah and yes next time do a search...this has been discussed in earlier threads.
Use sDobuler if you use more apps from PsiLOC with it,that is why its size is smaller.
I use Stacker.
You should definitely try them both,and then decide.
check these out... 😉
http://allaboutsymbian.com/phpBB2/viewtopic.php?t=6098&highlight=stacker
http://allaboutsymbian.com/phpBB2/viewtopic.php?t=6152&highlight=stacker
http://allaboutsymbian.com/phpBB2/viewtopic.php?t=6449&highlight=stacker
