My N95 is currently running on V20.0.013. A major improvement in update were found in V20.0.015. Now a days the latest firmware is V21.0.016.
Q1. If I update my N95 to 21.0.016, then would I get all the improved features of V20.0.015 as well or should I update my N95 step wise, i.e., first to 20.0.015 and then 21.0.016 to have all improvements. In V20.0.015, there were improvements in menu structure.
Q2. I have pre-installed multi language dictionary on microSD card provided in the sale package. If I update my N95 to V21.0.016, would this dictionary still work or I have to re-install it again?
Q3. Is there any problems which anyone encountered after updating N95 to V21.0.016? Any draw backs of this latest V21.0.016 software?
I totally depend upon you technical guys, and always get satisfied with the nice cooperation of this forum members. I hope you'll guide me this time as well.
Regards to all
erehman wrote:My N95 is currently running on V20.0.013. A major improvement in update were found in V20.0.015. Now a days the latest firmware is V21.0.016.Q1. If I update my N95 to 21.0.016, then would I get all the improved features of V20.0.015 as well or should I update my N95 step wise, i.e., first to 20.0.015 and then 21.0.016 to have all improvements. In V20.0.015, there were improvements in menu structure.
v21 improves further on the features found in v20.x.xYou Cannot "step-wise" upgrade - you get the latest version for your product code.
The dictionary data will be fine the application will require reinstallation, ensure you have a copy of the app before you upgrade.
Q3. Is there any problems which anyone encountered after updating N95 to V21.0.016? Any draw backs of this latest V21.0.016 software?I totally depend upon you technical guys, and always get satisfied with the nice cooperation of this forum members. I hope you'll guide me this time as well.
Regards to all
On the whole its a MUCH better version than v20.x I find the video works far better - bluetooth devices work much better too. Web browsing is better with FlashLite3 support.
Back-up your phone .. and upgrade .. ensure you have a copy of that dictionary application first.
Good Luck! 😊
Yeah the firmware doesn't upgrade the version that is on there, it replaces it. Thus, whatever version you install completely replaces what was there before.
it should have all the good stuff of the last one and none of the bad stuff!
