Emtube problem
5 replies · 4,034 views · Started 11 April 2008
I recently saved a video file from emtube on to my N95 8GB.
When i try and find the file in my gallery it does not show. The only place i can play it is within emtube playing a 'local file'.
I have tried using the search function on the phones main menu but to no avail.
Is there any way of having this as a seperate file on my phone (basically i want to bluetooth it)?
I am also now unable to delete this 'local file' within emtube. How would i do this?
Thanks in advance
just highlight it and hit the C button that should delete it
failing that, connect phone to USB port in data transfer mode and delete it that way
emTube downloads the flash file which Real Player on the phone can't play. You therefore have to play it within emtube as it has the player built in. The only way to make the phone recognise it is to convert it to something the phone will recognise like mp4 or 3gp etc
3Shirts wrote:emTube downloads the flash file which Real Player on the phone can't play. You therefore have to play it within emtube as it has the player built in. The only way to make the phone recognise it is to convert it to something the phone will recognise like mp4 or 3gp etc
If you want to be able to bluetooth the file, there's nothing stopping you converting the .flv file into the compatible formats above using either SUPER or 3GP Converter.
