7650: screensaver crashed
3 replies · 2,027 views · Started 03 February 2003
i �ve installed screensaver 1.01 PsINT but it didn�t work (the built in always appeared), so i tried to install it again but now the installation crashes:
'progr. closed. Main KERN-EXEC 3'
how can i delete the whole programm? and how will it work (so to say 'stronger' than the built in saver) than?
thanx!
Go to Tools, then Manager (?? its the first one, it says Gestor in Spanish if that helps)
You'll see the app there, put the cursor on it and select delete from the list of Options.
Alternatively, you can try directly from the menu (sometimes this does not work, don't know why
Paul
[quote="vau"]i �ve installed screensaver 1.01 PsINT but it didn�t work (the built in always appeared), so i tried to install it again but now the installation crashes:
thanx![/quote]
if you're a registered user, you get the latest version upgrade free. get the 1.15 version. 😃
thanx, but it is not there it is quasi in the desktop-folder and no chance to delete it!
