Final Question from Me re N985 8GB Codes!
1 replies · 2,316 views · Started 12 April 2008
Hi - having updated my N95 8GB to FW 20 using the NORWAY code everything works fine. I changed back to the EURO 1 code.
My question is: When I now run NSU with the EURO 1 code it says my phone is upto date with the latest software. Is there any difference between the 2 codes that I am missing out on as it no longer gives me the option in NSU to re-install if I want to.
No, it's just because your software on the device supercedes the version on the server. If and when a v25 (or whatever) comes out on EURO 1 code it will show you can update. The option to reinstall will appear when v21 is ready for EURO1
