Nokia E90 and 3UK
1 replies · 2,428 views · Started 12 April 2008
I have just acquired an unlocked O2 Nokia E90 and using it with 3UK. Everything seems to be OK but I can't get MMS working.
Any help would be greatly appreciated.
Thanks in adance.
Dunno if this will help but with most networks as some phones dont come with the settings preloaded you have to go onto the website and get them to basically send you the settings you then save them type in the PIN they give you (if requirred) and the jobs a gooden.
I know this is relevant for Orange, Virgin, O2 etc but dunno about 3.
Cheers
