help with bluetooth adapter
7 replies · 2,156 views · Started 03 February 2003
right just bought myself a bluetooth adapter that cost �89.00 got home tried to install the software and it tells me i need windows 98 second edition or higher wich i havnt got . it dont mention i need second edition or higher on the box so does anyone know if i realy need to install another version of windows or is theree some file i may just need to download ?
thanks
if anyone wants to know what type of adapter it is its the (konnect) type that they sell in the link (uk)
If you have 98 then you have to install usb drivers from micro$oft for that and then the BT should work.
If you have 95 then you are out of luck. Get 98SE
[quote="JyriK"]If you have 98 then you have to install usb drivers from micro$oft for that and then the BT should work.
If you have 95 then you are out of luck. Get 98SE[/quote]
i am using win 98 mate do you know the exact drivers i need to download please .
also how am i going to use the software that came with the usb adapter if it wont let me install it
thanks
Dont remember, search M$ for USB and windows 98.
So the BT driver installer doesnt start at all??
What drivers does it use then?? widcomm?
and could you tell me what software i need to download please to use this blutooth thing with
cheers
the software that came with the bt starts then says it need to be installed ion win98 second edition otr higher then stops.
i cant find the usb drivers i need .
anybody know what i need to download ?
anybody able to help me out please ?
i have no idea what to do here to get my bluetooth installed or the software i need .thanks
