Which E90 Newbie question :con?
2 replies · 2,308 views · Started 13 April 2008
Hi there people,
I am wondering if you could give some advice. I am looking to purchase a E90 of Ebay (Or if any one is selling one!) as i saw one the other day and i have fell in love with it. The question i have is there different versions of the phone. I have noticed on ebay some come with a 256mb or 512mb sd cards, is this because the ones with 512mb are the newer models. Some people also say things like this is the version with a flat keyboard does not scratch screen ???Are there different versions of the phone. I know that it depends what branded phone you get ie vodaphone, o2 etc. Which is the better model to get i know i will need to update the firmware etc.
Any help or advice would be greatly appriciated.
Many Thanks
Rob
Hello,
I suggest you to don't buy it from eBay. As you see some people changes the original 512k mem card to 256k one, you can not make sure that you get the fixed version and so on.
E90 is a great device I have it too and won't change to nothing else. It worth it to buy new one.
Cheers,
Personally i think bying from ebay is fine, just make sure to check the feedback and if your still not sure you can always msg the people they have sold to/bought from.
And about the difference in size that has nothing to do with the internal memory, that is just the SD Card that comes with the phone, and to be honest most of the time i keep the SD Cards aswell e.g. i got a 512mb card with my E90 and sold a Nokia n82 with a 256mb card because i wanted to keep the card lol.
And finally about the old and new versions i believe, people can correct me if im wrong buts theres not that much difference between the new and the old one apart from i think the firmware update, improved microphones/speakers as some of the phones originally had problems and the keyboard issue. But i have the older one (circuit under the battery stamped NR_12 as aposed to NR_14, or maybe its 'VR' cant remember) and i have had no problem at all with it. The screen marking is abit annoying but if your gentle with the outside phone and clean it once in awile its hardly noticeable.
Hope this helps
