trying to update my n95 8gb and in the nsu im getting phone not reconized and an error in nss can someone tell me whats wrong:con?
help
uninstall Nokia PC Suite .. and install the version that came with your phone (off the CD) Do NOT update when it asks you to.
run NSS and make the code change you require .. Then you can happily update the Nokia PC Suite etc.
An alternative method is to use a restore point prior to the PC Suite upgrade - this may prove tricky AND it might break other stuff.
Try that and report back.😊
seki wrote:uninstall Nokia PC Suite .. and install the version that came with your phone (off the CD) Do NOT update when it asks you to.run NSS and make the code change you require .. Then you can happily update the Nokia PC Suite etc.
Uninstalling Nokia PC Suite and using the version that came with the phone does not work as when you go to run NSU (version from the CD) it tells you that there is an update and forces you to either update or exit before continuing
