SMS Synchronization
3 replies · 2,928 views · Started 15 April 2008
Hello all. Yesterday i bought Nokia E90. But as i have 2 sim cards it`s boring to replace them always. So i decided to do such a thing if it is possible. I want to buy some (X) cell phone, insert in it SIM. when the SMS comes to SIM on (X) phone it must send it via Bluetooth ( i think it is the best way ) to my Nokia E90. As for Nokia E90, it must receive it as new message ( it`s do not matters what kind SMS, Mail or smt. ) But when i reply message that came from (X) phone it must be sent throw (X) phone not from Nokia.
Is that possible? And what second phone do i need if it is?
thank you all for your replies ! Have a nice day!
Hello,
I see that you figured out the solution yourself, you need two phones (actually you can find phones with 2 sim capability).
Yes you can buy an X phone with bloetooth and send you sms's to your E90 manually.
You can try to connect both phones to your computer and with PcSuite will be easy to manage your messages.
cheers,
swingerman wrote:Hello,
cheers,
I mean i have NokiaE90, and i want to buy second phone (X). But i want to figure it out can i automatically send all incoming messages to E90 from (X) phone. And when i reply those messages on E90, they must be send throw the (x) phone.
Yes, i can buy Samsung Duos and have no problem, or Fly B700. But i love my communicator and i want do all the things throw it!
Also there is a little problem that i am Mac user so i cant setup Nokia PC suite on my Mac.
So the question is open, Thank you for reply!
I found the program i need but it is for PDA based on WM phones. Uhhhh it`s name is Smart GSM is there alternative for symbian?
