When the N95 is conected to my bluetooth car kit the Sat Nav voice is silent but when Bluetooth is disconected it's Ok. Does anyone have any ideas on how to solve this?
Hands Free Bluetooth Conection
Are you connecting to bluetooth before starting sat nav? I had the same problem if i started maps before connecting with bluetooth.
Also there are different bluetooth profiles supported by different kit. Does the bluetooth play back every noise the phone makes or does it only do so for calls?
when i use a bluetooth handsfree kit - i get ALL sound routed through the headset. this includes sat-nav guidance. a tad annoying really but not sure you can do much about it...
