Dominique HUGO has released another version of FileExplorer that fixes some minor bugs and has some more features. Go to www.gosymbian.com for more info. The new version includes this:
Version 1.07
-the info-boxes of the drives and files properties have been
enhanced, also added the hidden,archive,r/o and system
attributes of the files and the 3 UID's.
-the restart function is, now, in a phone menu which gives
also the info about the phone (imei, firmware version and
date).
-in the cut/copy/paste system, a dialog box appears in the
paste command if the file already exists to confirms its
replacement.
-when asking for 'the properties' on a folder, it gives the
number of sub-folers and the number of files under the
current folder.
-when copying a file, the attributes (of the destination) are
reset (eg: R/O is off if the source was on); this allows to
copy files from the z: drive and delete them after.
-when renaming a file, the old filename is displayed in the
rename dialog box.
-when a 'search for files' is performed from the root, the
'edit' menu is activated.
-'enter' on a drive causes an enter on this drive and 'left
key' on a drive causes to display the properties box of this
drive.
