Nav4all 'tests'
6 replies · 6,215 views · Started 21 April 2008
Theres some very amusing 'tests' carried out that apperently means nav4all out performs TomTom, and various others.
http://www.stichtingonderzoeknavigatiesystemen.nl/eng/certificates2.php
However, this domain is run by the same people that run the nav4all site, what a coincidence?
But seriously speaking, I have rarely seen such blatent rubbish.
I dont know if nav4all is any good (never tried it as its an 'over the air' satnav package), but I heartily recommend people avoid it in light of this.
PMSL !! That's quite unbelieveable !!!
Did they really think they could get away with that ?
I have been using TomTom on my S60 phones for a few years now, and I have also tested Nav4All, Amaze & Nokia Maps, none of which come anywhere close to TomTom for accuracy, ease of use and feature levels.
With TomTom looking ever increasingly to have dropped the S60 versions for good, I am weighing up my future options, but would have to say that Nav4All and any other "over the air" system doesn't just fall to the bottom of my list, it simply doesn't make the list. Period.
I know it's hard for these smaller, independent companies to compete with the big boys, but the best way to do it is to simply come up with a better product, not lie and deceive through marketing.
Shame on you, Nav4All !! 😡
Hmmm, on further searching it appears that report was quite reported.
Ended up on the register, Vunet, and quite a few others.
Might be worth looking into I reckon.
quote a pdf on there:
TomTom fails to find the ring roads and consequently uses roads through residential areas and other roads that are not intended for through traffic.
Good... means I'll get there quicker.
i have been using tom tom one for a while (until it got nicked from my house :mad😊 then i found nav4all on the wap browser and thought what the hell im lost cant do any harm, so i downloaded it and i am finding it a lot easyer and less confusing than tom tom there are some very usefull parts to nav4all you gotta try it to find out you may aswell its a free app
