v21 keeps resetting itself....
3 replies · 3,160 views · Started 22 April 2008
before updatin from v20 it kept freezing up and had to remove battery to reset
now it keeps restarting itself but its weird tho the screen shrinks til its small and the screen is black.
anyone had similiar problems?? maybe due to be restoring back up from memory card?
wkc247 wrote:before updatin from v20 it kept freezing up and had to remove battery to reset
It's never a good idea to restore a backup after a FW upgrade or de-branding.
A simple format of internal memory should sort any problems this has caused.
Type *#7370#
If the handset is still crashing & rebooting after this, you either have a hardware fault or something in your MicroSD memory card is corrupt (try removing the card).
Hope this helps.
wkc247 wrote:would i lose anything from the internal format?
Phone numbers, calendar entries - anything that was installed in the phone memory really.
However, it is safe to 'Syncronize' most of the above using PC Suite Sync function. Then Synchronise again after formatting the memory.
Depends which is more important to you? Having to reinstall some apps manually or having a handset that's a bit unstable?
