Face drawing software
4 replies · 2,497 views · Started 04 February 2003
Hi
i've downloaded a program for our P800 for face drawing but it is a .Jar.
Does any one know how to exe this file.
N.B. i've tryed double click to self extract but it didn't work
Quite simple ericsson have a instruction located at this address
www.ericsson.com/mobilityworld/sub/open/technologies/ java/docs/install_java_in_p800
basically what it tells you to do is to copy the jar file to your phone in windows explorer by dragging it to either root of the phone memory or the duo card.
Then in flip-open mode you select Applications->install.
another way to install jar file is to send it to P800 as a message. for example connect the P800 to your PC(I tried with IR) and then right click on the jar file/send to IR device. This goes to P800 as message stream and a message pops up at P800 with an option to install. you simply tap on install button and there you are!!! Best of Luck
BTW let us know how the software worked and from where you got it?
lol...this software is just meant as a joke I think..kinda funny..
Anyways, try it out for yourselves:
